Thanks
At this time, I do not know what brake fluid I want to use. As I stated in my first post, I am trying to find out what SAE 70 R1,or 70 R3 is. It could be Dot 3 or something, but I don't want to quess if I don't have to. If I had to quess at something, I would go with DOT 5.1 which is borate ester based, thus its compatibility with DOT3 and DOT4. See info below. However, I will see what MacGregor had in mind when he wrote the manual. I will not go with a silicone base product.Thanks for all your inputs.POLYGLYCOL ETHER BASED FLUIDSFluids containing Poly glycol ethers are regarded as DOT 3, 4, and DOT 5.1. These type fluids are hydroscopic meaning they have an ability to mix with water and still perform adequately. However, water will drastically reduce the boiling point of fluid. In a passenger car this is not an issue. In a racecar it is a major issue because as the boiling point decreases the performance ability of the fluid also decreases. Poly glycol type fluids are 2 times less compressible than silicone type fluids, even when heated. Less compressibility of brake fluid will increase pedal feel. Changing fluid on a regular basis will greatly increase the performance of the brake system. FLUID SPECIFICATIONS All brake fluids must meet federal standard #116. Under this standard is three Department of Transportation (DOT) minimal specifications for brake fluid. They are DOT 3, DOT 4, and DOT 5.1 (for fluids based with Polyalkylene Glycol Ether) and DOT 5 (for Silicone based fluids). MINIMAL boiling points for these specifications are as follows: Dry Boiling Point-Wet Boiling Point DOT 3 401ºF 284º F DOT 4 446º F 311º F DOT 5 500º F 356º F DOT 5.1 518ºF 375º F DOT3 is an aliphatic polyether.DOT4 is borate ester based.DOT5 is polydimethylsiloxane (silicone based).DOT5.1 is borate ester based, thus its compatibility with DOT3 andDOT4.DOT 5 is very different--it's silicone based, doesn't absorb water, isn'tcorrosive, is bad for some seals, is hard to bleed, and is not misciblewith 3 or 4. Stay away from it--it needs a system designed for it. More information can be obtained from the following standards documents:DOT3: SAE J1703DOT4: FMVSS 116; proposed SAE standard J1704DOT5: SAE J1705DOT5.1: No SAE spec
