Help with procedures prop shaft alignment
Jun 18, 2006
62
hunter Cherubini Hunter 37 cutter Cocoa Beach
So, my current situation is that my boat is on the hard, after withdrawing the propeller shaft I found that the strut was installed so incorrectly that it was virtually impossible to get the shaft back into the transom hole. The stern tube had rotted into bits of decomposed bronze. So I have purchased new motor mounts, a new Cutlass bearing, new stern tube and I will loosen/remove the strut for the shaft.
My plan of action is as follows and I welcome any commentary, even if it has to do with alien abductions and trans medium craft. After installing the new motor mounts, I will run the motor for a bit throttling it this way and that and then let the motor sit for a couple days while I do other projects. Then I will put the shaft into the coupler and move the engine about with the mount Adjusters such that the shaft is centered in the stern hole. I will note the amount of play at the end of the shaft with the propeller removed and I will work on centering the shaft in that amount of movement at its end . I will support the shaft in some fashion or another in the center of its movement . Then I will install the stern tube, making sure that it is equidistant from the shaft with a spacer and I will also install the strut, using thickened epoxy to get a proper set such that, with the new Cutlass bearing, the strut will be centered on the shaft which will be centered in the stern tube which will be bolted up to the transmission. I will be installing a Volvo lip seal and after I get all of these things fitted I will install an R&D flexible drive shaft coupler. After I splash the boat I will make some attempt at measuring the alignment but from my understanding, a beefy hull and a well-centered drive shaft should not vary that much from the difference in Hull flexion from being on the land versus on the water. In the end I will have new motor mounts, new Cutlass bearing, new Stern tube and new prop shaft seal, warp drive, photon torpedoes and retractable landing gear. All laurels, darts, and conspiracy theories are welcome.
7,457
From what you describe, I think you are in for a full blown alignment. Biiiiiiiiiiiiiiiiig deal. Just a lot of cursing, swearing, and Klingon curses. Learn how to align a prop shaft correctly with the attachment below :
960
Hunter 27 Pecan Grove, Oriental, NC
If it is like my H27, the stern tube is the only part of the assembly that only has one spot that it can be located. I would fit it first and then slide the prop shaft in with a spacer that will keep it centered in the stern tube. Hopefully the shaft will come close to the center of the engine coupler and in an position that works with the placement of the cutlass bearing strut.
7,605
Alden 50 Sarasota, Florida
my experience is that all hulls flex, some more so than others, so consider yourself lucky if you can avoid another alignment after it sits in the water for a while.
Jun 18, 2006
62
Thank you for the informative link . I understand that it is rather important. However, if the shaft is bolted up to the transmission, free of any encumbrances, and then the stern tube and prop shaft strut are installed, centered on the shaft, I should be starting out with perfect alignment, minus whatever Machining run out there is on the face of the coupler. I am hoping to take the shaft and coupler, which should have been mated properly upon their installation, to a machine shop to have them evaluated and machined. When one aligns an engine, in truth they are aligning it to the prop shaft strut. I will be doing the reverse, which is mounting/aligning the prop shaft strut to the engine.
Jan 7, 2011
5,879
Oday 322 East Chicago, IN
I am not sure that you have ways to adjust much after of the engine. On most boats, the strut and cutlass bearing, and the stern tube/shaft log are not adjustable. You move the engine up and down as well as change it’s angle, to get the shaft to line up properly in the strut and stern tube.
When I replaced the shaft, coupling and stuffing box hose a few years ago, I slid the shaft through the strut (without the cutlass bearing in place), then into the stern tube opening. This was hard because I did not remove my rudder, so I had to pull in the shaft a bit to get it started in the opening. Then I slid it in until it cleared the rudder…then I pressed in the cutlass bearing. Then from inside, I centered the shaft in the stern tube and used some sticks or something to keep it centered. Before I put the stuffing box in place, I slid the shaft up to the transmission flange and made sure. It was centered. Satisfied with that, I removed the sticks holding the shaft in the stern tube, installed the stuffing box hose and then the stuffing box. Finally, I pushed the new coupling on the shaft and pushed it up to the transmission flange. I bolted the flange and coupling, and carefully rotated. The shaft to see how tight it fit against the output flange. Looking good, I used a feeler gauge to see if the “gap” was consistent all around the coupling. In my case, I did not need to make any engine adjustments.
Remember that once you put the boat back in the water, the hull will probably change a little, so a small adjustment maybe required after the boat is splashed.
I don’t know if tis of any value, but I made some videos of my project….this is the last in the series of the shaft replacement…I didn’t capture every moment of the project, and I don’t have any video showing the use of the feebler gauge, ut maybe it helps in some way.
A year later, I removed the coupling and replaced the stuffing box with a Volvo dripless seal, and had to go through some of the steps again…
Good luck.
Greg
Jan 4, 2006
7,457
You would be far more correct to say the Earth is at the centre of the Solar System.
Replacing the motor mounts alone will guarantee that the angular alignment is out by at least 0.050" to 0.100". You will be aligning your engine to a maximum error of 0.001"/inch of coupling flange diameter in inches. There is no way you can install the engine to replicate its original location. AND there is no reason to believe your engine is currently aligned unless it has been recently aligned.
Far more important than that. Unless the alignment is done with some sort of system, it's out of the question.
I hope you're not thinking of "vertical and horizontal alignment" only. This can be done by fingertip feel if your comfortable with alignments. If not, use a straight edge. Unfortunately, many couplings are not exactly the same diameter so it's back to the fingertip method. They are not the important measurements just because of your rubber mounts. Lean on your engine and see how much the vertical and horizontal alignments change. No stress on the shaft so no foul.
ANGULAR alignment is the one to be concerned with and it's a bit of a bugger (time consuming) to get correct.
Please read (and understand) the alignment theory and instructions offered in the attachment found in post #2. Understand angular alignment before you even get close to your engine.
Follow Greg's videos in post #6 as they are excellent in following a procedure. I often suspect he was a movie director in a previous life.
C&C Frigate 36 St. Margarets Bay, Nova Scotia
@heritage has given you good advice here. I did it all, except a new stern tube, on my H37C. Install the stern tube, then adjust the strut mounting to align the the shaft axially in the stern tube and then the engine (final adjustment in the water). The stern tube becomes part of the hull; everything else is just adjustable. Keep the process logical and (hopefully) simple.
Nov 14, 2016
36
Hunter 386 QCYC
I am in the middle of doing the same thing on my 386. The previous owner had taken out the key holding the shaft in the coupling, bolted it back up ... then stopped paying winter storage fees and I bought her. After a few years (last year), the prop shaft fell out of the coupling (only a press fit, not a split coupling). So, the end of the shaft was completely buggered. Luckily the anode was positioned such that the shaft did not fall out of the boat (something to plan for).
I have replaced the cutlass, shaft, coupling (split, machined face fit) and PSS (replaced the stuffing box). Boat is still on the hard, so not finished. The new cutlass in the strut really is, as noted by Tally Ho, the centre of this universe - I suppose you can tinker with it with the epoxy, but, once set, it rules the roost.
I positioned the shaft exactly half way over the cutlass - equal weight on both sides and measured the angle of the shaft on both sides of the cutlass, very close to rule out flex. Put the shaft up near the transmission, and adjusted the engine mounts (the engine mounts are in my case, the primary source of alignment adjustment), so that the shaft, right up against the unbolted couplings, was the same angle as at the cutlass. The point here is that at the same angle, the Shaft is straight, with no flex, between the cutlass and the coupling. Soft bolt the coupling into the tranny (soft bolt means I have not torqued it down, but it cannot shift or move. This movement of the engine until it is all aligned is a bugger. Your best friend is time - you cannot be in a hurry, or get frustrated easily. Three dimensions - left/right (X dimension) is easy, except the engine has to be exactly aligned with the shaft. That is, you can make the engine/transmission exactly parallel with the shaft ... but it can be transposed or shifted up to half an inch!. This is true for the Y plane as well. And then there is Z (whole engine up and down). You must - and certainly with new engine mounts where everything is new - make sureyou raise/lower the entire engine - maintaining whatever alignment you have at the same time.
The instructions above seem pedantic, but, in their absence, eventually, the pressure on the grub bolts and shaft will destroy one of the elements.
I have yet to put her in the water, but my expectation is that the engine will drop (because the full weight of the boat is currently on the keel) a small amount as the weight of the boat becomes distributed over the hull, and the keel will drop relative to the hull. So, you then have to be prepared, in the final adjustment stage (not sure how long it will take to" settle" - I expect a month in the water - just guessing), to tweak all 4 engine mount bolts again presumably turning the adjusting nuts the exact same number of turns all around as the engine/tranny settle relative to the cutlass/strut.
Patience Obewan.
Jun 18, 2006
62
Patience Obewan.
I feel like I have an enormous advantage. Given that I am removing the shaft strut, nothing to do with the strut is a fixed position. So for me, my only fixed position is the hole in the transom. I will be putting in a new Stern tube so even the angle and position of that can be adjusted somewhat before the 5200 cures. So I will bolt up the shaft in coupling and get it centered in a transom hole and then install the stern tube with some spacers such that it is oriented correctly and then bolt and 5200 it. The shaft strut will be installed onto the shaft and thickened epoxy used to set the alignment of the strut, along with the mounting bolts of course. Seems a lot easier than trying to get the engine to align with two fixed points, those being the Cutlass and the stern tube. After the 5200 and epoxy has set, I will install a R&D flexible coupler. One thing worthy of mentioning is I will certainly run the engine with the new motor mounts and let it sit for several days as the rubber May settle in one fashion or another. This before I secure the stern tube and shaft strut. In my mind the whole idea of having a shaft so long hard fixed to the transmission seems absolutely silly! Why not a couple CV joints and the shaft having a flange which Bears on thrust bearings?
Hunter 27_75-84 Wilmington, NC
Hey, good luck as you move forward. About 6 years ago I replaced my prop shaft, cutlass bearing, stern tube and shaft flange on my 1984 Cherubini H27. I had previously (2008) had relaced the original Westerbeke ten2 engine with a new Yanmar YM2-15. I'm now over 4300 hours on the new engine. In my experience, the key item, frequently overlooked, is to center the shaft in your new stern tube through out the alignment procedure. it is the one element the can not be adjusted. Tony
Jun 5, 2010
1,133
Hunter 25 Burlington NJ
What Heritage said, for reasons Jim Legere said.
I would add the (strong) suggestion to make the stern tube from G10 tubing and not bronze at all. Cut the hole through the boat bigger than it has to be. Align the motor with the shaft strut only and let the stern tube float in the hole. If you have the dripless gland already on the shaft, clamp it to the stern tube and go outside to align the tube on the shaft. I mean put on the prop and everything. Start the engine and put it into gear. When it all looks happy, ‘glass the stern tube where it lies. Inside and out. When that’s done, slide the shaft out and grind the tube off outside to be fair with the hull. Or you could even let it stick out a little because that’d be easier to ‘glass it. Add more ‘glass and 3M fairing compound as needed. Prime with epoxy barrier coat and paint.
I would not do a new installation with an antiquated bronze shaft tube for all the tea in China. I mean to install a diesel in Diana next winter and this is how I’ll do it.
Also - the only material for the shaft itself is Tobin bronze. SS should never be used for underwater hardware. That’s for motorboaters. The only metals you should have below the waterline are the shaft and the prop, because bronze is the best thing for those. Fit your zincs and avoid the need for electrolytical bonding.
