Does anyone know of any other motors that share parts, (prop housing) with the Honda B75 (7.5 hp)?
4 of the impeller housing bolts snapped off. They are surface level and below, (the housing already removed) so I am not able to get a bite on the studs.
I have tried penetrating oil, tapping, heat, drilling and extracting with no luck what so ever. This is some kind of chemical bond or serious corrosion.
I have searched for parts, but having very little luck finding things for this motor (honda b75 serial number 4000-10000, mid 70's, as far as I can tell). My question is this: Is there a motor that is more readily available that I can just bolt on a new or used prop housing, that has same gears etc?
Any info is greatly appreciated.
Thanks,
Dave
Thanks,
Dave
