I purchased a '95 H336 last September, and have been fixing various things the previous owner didn't attend to. I have a 3GM30F engine. I discovered that the regulator was fried in the alternator, so I took it off to have it rebuilt. I had noticed that when the engine is running, the alternator was wobbling around a bit, and there was quite a lot of belt dust on the inside of the engine enclosure. When I removed the alternator, I discovered that an undersized bolt had been used in the top mount, which allowed quite a bit of play, causing the wobble. It had even worn the hole in the mount into an oval shape due to the wiggling around. When I went to remount the rebuilt alternator, I picked up a 10mm bolt, which fits the mounting holes in the Hitachi alternator perfectly. The bolt won't go through the mount, however. So my question is, does anyone know what size and type of bolt is used in the top bracket? I'm considering picking up a 10mm drill bit and enlarging the top mount holes so that my 10mm bolt will work, but before doing that, I'd like to see if anyone can tell me if there's something else I should be using.
