L
Libby Thompson
I have been frustrated for three months..... I replaced the bronze factory shaft with a stainless shaft direct from France for my Beneteau First 35.New cutluss bearing, new PSS dripless, and the original fixed two blade prop. I own a Maxi Prop, but the stainless shaft nut threads do not match the new prop, so I had to install the fixed blade. I plan on reinstalling the new prop when I can have a rethreading job done on the nut.In the meantime, my boat is out of commission. I cannot even leave the dock in forward gear. At 900 RPM a shock wave develops from the aft shaft area outside the boat and resonates through out the shaft and engine and shakes the boat violently. I at first thought it was the gear box, so I had it checked out. Then I had the engine checked and the motor mounts and the engine realigned. All checked ok. I called the parts dept. at Beneteau and all I got was that they are willing to sell me another shaft! The shaft was sent direct from France and there is no warranty.Has anyone had this problem with a replaced shaft?
