How would you repair this?The chainplate was obviously leaking on the H23 before I bought it and has Rotted the bulkhead or chainplate mount, whatever you want to call it. (It’s not a full bulkhead)It appears the wood is only rotten where the chainplate bolts to it and a little along the top. It is solid all along the hull and about 2” below the chainplate.The bulkhead is not all that big, probably 16” tall by about 8” or so wide at the top.Obviously the best repair would be to remove the whole bulkhead and re-glass it back into the hull. The problem is that Hunter really glassed it in well and I don’t know how I’m going to cut it out without damaging the hull. I don’t know what tool I could use to cut the bulkhead out close to the hull. I also thought about just cutting the rotted portion out then re-gluing a new piece in and tying it into the old wood with a stainless steel plate of some sort.Was the wood glued to the hull first and then glassed in? I though I might could take a dremel or a 4” grinder and just cut through the glass, but if its glued to the hull I don’t know how I would separate that. I also had hoped to get the old one out whole so I could use it as pattern for the new one.Any help or suggestions would be appreciated.Also the wood is ¾” ply, but I don’t know what kind. What would you replace it with? I can’t get Marine grade around here without ordering it and that would be very expensive.Photo attached….Thanks James
