Benny
The valve to the thru the hull for the galley sink broke off the turn handle. It is a gate valve but I would like to replace it with a ball type. This is under the water line and because of its location inside bottom of the starboard Lazarette it is hard to get at. The boat is a 1983 27 Cherubini. My question is about the size of the thru the hull. Is it a 1 1/4 inch or a 1 1/2 inch? When I rmove the broken valve I would like to be able to screw the new one in without getting to much water in the boat. Would it be really necessary to place a plug on the outside? Also I'm concerned with the possibility that while trying to unscrew the old valve that I may foul the thru the hull as it seats in its base. The wood spacer is a little rotted and pieces are starting to come apart. Any comments from someone who has done this before would be appreciated.
