Help pleasse Catalina 400 mk II experts
JBS
Mar 22, 2014
7
Cataina 400 mk II Booker Bay
Hi all newbie here from Australia.
I got my first sail boat at Christmas, a 2000 Catalina 400 mkII. From the boat survey (which I attended for a whole day) I ended up with a pretty respectable to do list which I am steadilly working through. This weekend I was working in the forward head/shower. The shower drain pump has no hose on its discharge, removed for one reason or another. I found the through hull 3/4" seacock but would like to know what the manuafcturers route was for the hose . In the forward V birth floor panel there is a hose loose but it looks more like a drain way into the bilge from that space and if it was for the shower it has been cut short. If someone could enlighten me it would be muchly appreciated.
Thanks
Jonathan
May 17, 2012
21
Catalina C400 Corner Brook
I have a 400 Mark 1 and the forward shower exits the boat thru a thru hull under the seat in the forward cabin.
See attached file for thru hull locations.
Hope this helps
Byron
C400 Hull146
444
Catalina 400 mkII Harbor
on mine it goes from the sump basin through a vented loop that is behind the mirror. then to the thru hull.
mike
JBS
Mar 22, 2014
7
Hi all. Many thanks for the responses. I will check these out.I am going to attach a rodding line at the suspect through hull fitting and see if appears at themystery loose hose under the forward cabin floor. I'll let you know how itgoes.
Thanks again
Jonathan
