cutlass press operation
from the web site:::The bearing remover in use: Drop the forward plate over the prop shaft between the strut and the hull. Then slide the bearing pusher, followed by the aft plate, over the end of the prop shaft. Connect with threaded rods, washers, and nuts. Tighten the nuts to push the bearing out. That's it. Once the old bearing is removed you'll have to use a Dremel tool to cut it from the shaft. Of course, you can use this tool to push the new bearing back in, just slide the new bearing over the end of the prop shaft, and omit the pusher.
