Ben Romano
Please verify and/or correct the instructions below concerning lowering the mast on our 1993 Hunter 23.5. We have reversed the instructions for raising the mast found in our owners' manual. Does anyone have better instructions or step-by-step procedures for lowering and raising the mast? HELP!1.Remove mainsail sheet, boom and mainsheet block.2.Attach mast raising bridles into slots on mast and hook the pelican hook to eyes on the forward stanchion legs. Make sure that bridle wires are snug equally on port and starboard.3.Install crutch in tube at stern of boat.4.Attach mast raising tube.5.Take the main sheet block assembly and connect the cam end to the V-volt in the anchor well and the other end to the forward loop on the mast lowering tube.6.Attach jib halyard to aft loop of mast lowering tube. Cleat off jib halyard to cleat on mast.7.Unpin mast from mast step.8.Lower mast until the mast is resting in the mast crutch.9.Make sure that side stays are connected to the “U” bolts as the mast is slowly lowered.Thanks for your help! Hope to see you on Pensacola Bay!
