Do it in the water!
John,I replaced my rudder while it was on the hard, but it should be easy for you to do a repair while in the water assuming you only need to replace the cap.First of all, if you have wheel steering, the quadrant will prevent the rudder from falling out & you should be fine.If you have tiller steering, then all you would need to do is use a clamp, pipe wrench or huge vice-grip pliers & clamp it down TIGHTLY on the rudder stock. I'd lift the rudder 1/2" & clamp it where the stock meets the lower bearing. You can then rest the weight of the rudder on the clamp to test if it will hold during your repair. If it does, then remove the cap & replace/repair as necessary.Hope this helps!Allen Schweitzers/v DrambuieC-30 Hull# 632
