OK.. With no wind to speak of, the admiral and I went out to recalibrate the autopilot after I added the new rudder sensor. Barely out of our canal, the engine overheating light began to buzz.... I looked at the new temp gauge that I installed off the outlet to the water heater. This showed 140. First thought was that the thermostat failed. However, not being certain, I shut down the engine and went below to see if something failed. Everything was OK. Before we set out, I checked that the sea water pump was working. Not being able to make sense of what I was seeing, I started the engine and made our way back to the first available dock. I shut down the engine.
Let me add that as we were making our way back under the buzzzzzing of the .... buzzer, the admiral noticed that the new temp gauge was shooting up and peaked just south of 200 degrees.
After we docked I looked to see if the raw water filter was clogged, when it hit me as to why the temp gauge took so long to reflect the coolant temperature. First I went to see if there was a leak in the new coolant lines that I just ran to the heater. Nothing... Then I touched the hose. It was cool. I check the hose closer to the engine... while it was warm near the engine, it was cool just a foot or two down the hose. This is when I realized it must be the Fresh water pump!
Has any faced this problem? Does my analysis of the problem seem correct before I rip the engine apart? Has anyone ever repaired or replaced the fresh water pump? Could it be something else?
Hope everyone is having/had a "cooler" weekend.
Thanks
Jon
Thanks
Jon
