Help Loose Strut on Irwin
Bill
When the boat was put up this fall I found the strut to be loose. I'm use to the big heavy power boat stuff so seeing the strut disapear into the gelcoat surprised me. Does anyone know how irwin fassened the strut to the hull and what needs to be done to make it right again?
K
Kevin
Not real sure.
I would not be completely sure how it would have been attached but I would venture to say that it was inserted into the gel coat/hull and fastened by bolts from within the bilge. Some company’s used bedding compounds, such as Sicoflex, which over time can loose its adhesion capabilities. Not an uncommon assembly. http://irwinyacht.com/assoc/iyoa.html This was a site which I saw that may have some info as well. Hope it helps. Kevin
