Vang install
This is from Mark at Garhauer:Note that they have inadvertantly shipped units without directions. If you didn't get directions, call mark to have them sent. Phone: 909-946-6194Place electrical tape on back of brackets as gasket to prevent corrosion.Compress vang fully for installtion. I compressed it then put a stop knot at the last block to keep it compessed.Install mast bracket first, as low as possible, but check for deck clearance with bottom, block, etc. (esp. if you have a hinged msat step for lowering/rasing mast)Then install boom bracket.Install with boom at lowest position (best if sail is up) or with boom level.Drill and tap:Note I dimpled/drilled/tapped the first hole and installed the bolt at one corner, then the second hole at the opposite side/corner. Then did the rest of bolts while the first two held the braket firmly in place. If you try to do them all together, you are less likely to have the holes line up right.1. Using the bracket as a guide (I tied the bracket in place with a couple short lengths of line), use a 1/4 drill to just dimple the Mast/Boom in in center to make a guide --DONT DRILL DEEP.Drill through with #8 drill -- .199 inches dia.Then use a 1/4 -20 tapTake your time and think each step through, It isn't too difficult.Good luck, Tom
