Help identifying these electrical leads
Feb 6, 2013
437
Hunter 31 Deale, MD
These images are looking aft along the port side of a Yanmar 2GMF on a 1984 Hunter 31. I discovered this while I was removing the old insulation from the engine compartment. Can anyone tell me what these leads should go to? I have a feeling it is a high temp alarm and one of the previous owners thought it was a nuisance.
1,144
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
Kloudie will know but these items are shown in the electrical diagram of your manual. As I recall the blue is not used except on the 1 GM. I don't remember the other unused items.
Charles
Feb 6, 1998
11,711
Do you by any chance have a high output alternator installed? I really can't make out that plug nor the wire colors in the pic...
Jan 30, 2012
1,144
Did not see picture 2. My comments are good for picture 1 only. By the way the other one in picture 1 is an alarm feed (boot leak) if you have a sail drive - the colors are black and red/white.
Charles
What are they connected to at the engine side. We've found that pictures of wires hanging in space are pretty hard to diagnose on the internet without a wiring diagram or at least some kinda clue. :):):)
PGIJon
Mar 3, 2012
856
Hunter 34 Punta Gorda
The attached document may help... I'm assuming that this is a Yanmar.... You may need to uncover the wire colors
10,104
Exactly, Charles.. The blue is only used on the 1GM so it is where it is supposed to be.. The two wire connector... if that white looking one is actually a white with red tracer, it is the water alarm for a saildrive, which I don't think was installed on the H-31.
The big one with a boot on it, I dunno about.. If I were to guess, I would say that it might be (have been?) the "E" lead or ground lead from the original alternator.
Jan 30, 2012
1,144
As to picture 2 the cover boot makes me think 12 DC hot. The boot is surely factory Yanmar. The only two- wire boot protected item I remember is at the starter solenoid 'B' as shown on PGI's diagram.
Charles
