Help I need replacement parts!
2
- - Polson, Montana
I have a 1985 28.5 with cracked and missing outer trim on those odd shaped port and starboard windows. I need to replace them. Does anyone know where I can purchase replacements? Thanks in advance, Rob
Jun 10, 2004
19
Hunter 28.5 Mandeville
My '87 28.5 does not have trim
My 1987 Hunter 28.5 does not have any trim around the forward trapazoid shaped windows. Maybe you could just remove the trim totally assuming it is not part of the sealing of these windows.
K
Karl
plexi windows
order from the hunter factory or remove one and have a sign shop fabricate you two of them as they work in plexi all the time. A simple task
K
karl
windows
Look at the later hunter 28.5s and duplicate the design in plexi.
COM
Jun 24, 2005
7
Hunter 28.5 Salem - Alabama
Mark Plastics
I have an 85 28.5 and did this 2 years ago. The plastic trim you refer to is no longer available anywhere. I touched base with Mark Plastics. Mark agreed to tool up to make these frames since it was a common model. Mine fit perfectly. Mark should be able to take care of this for you if he's still in business. Mark Plastics 369 East Harrison Street Unit G. Corona, Ca 92879 909-735-7705
