OD 22 Replaced Tiller
Guys, one of the very first things I did on my '75 OD22 was to replace the seemingly original wooden split fork tiller. After scouring boat stores, internet, etc., I decided on a J22/J24 laminated wooden tiller--it's 43" long with a 7" rise at the forward end (clears my knees beautifully vs. old straight tiller). It seems like a really good length, too.I also bought some J22/J24 tiller stiffener straps. These are two bookend matched pieces of stainless angle iron that bolt onto the square butt end of the new tiller (like a sandwich) and there is one larger hole in the rear end of the straps to pass a new stainless 1/4" bolt through the rudder head. I also put some big nylon washers in-between the rudder head and straps to cut down on friction and to make it easier to lift the tiller to vertical position for tacks and when at mooring (so it's out of the way).I found these parts at APS (Annapolis Performance Sailing) [see related link]. They look very professional and work wonderfully. The price for whole project: $49.95 for tiller, $59.95 for pair of tiller stiffener straps and a few bucks more for s/h and stainless nylock nuts, bolts and washers. I'm sure some of you more gifted folks could probably craft these items in your shops for much less--I couldn't wait to do it myself and coughed up the bucks. I was also very afraid the ancient old-style forked tiller would break easily under stress--this new, updated/upgraded version is probably now one of the strongest things on the boat.Next time I'm at the harbor, I'll try to take a couple of photos of the finished project for those who might care to see what I'm babbling about.P.S.: Before I installed the new tiller and straps, I clamped the whole sandwich together with multiple clamps and ran my pivot bolt through the rudder head to make sure it was all lined up correctly and would look right when finished. I marked the holes to be drilled in the butt end of the tiller just in case my sandwich fell apart before I could drill my bolt holes. I also drilled those holes with a drill press to make sure they were straight and plumb. MOST IMPORTANTLY, this pre-fitting exercise allowed me to position the butt end of the tiller far back enough within the sandwich of straps so that the butt end of the tiller would rest perfectly on the built-in ledge/notch of the rudder head when all was installed. Doing that keeps the tiller from falling lower than horizontal and rubbing on the stern rail. If you plan to do this, go ahead and order your parts and I'll try to get my detailed photos posted here within a few days so that you can see exactly what I'm talkin about.P.P.S: Note especially, if you're going to order the tiller with the 7" rise from the website, their item #'s and descriptions are incorrectly reversed. You want the #HM112F tiller $50.95 (even though it says "wood tiller J24"). Trust me--I got the wrong one and had to send it back while waiting for the other one.
