Avoiding the Malaise
Gerry,First you need to take positive steps to avoid sea sickness; such as, not spending too long below deck or pouring over the chart table or cooking meals. Do as much passage planning as possible before starting out. Fill the thermos and make sandwiches etc. Enter plenty of waypoints into the GPS and have the list in the cockpit together vwith the GPS set.If you, or any of your crew does need to go below to rest, immediately hit the sack and get horizontal within seconds. Sometimes we don't even take our oliskins or boots off. Lay down and then kick off the boots and cover over with a sleeping bag.Likewise don't waste time below when coming back on deck.Don't get involved in hanging down into cockpit lockers looking for things - just straight in and straight out.Now we come to the pill. Stugeron is a cure for Menieres disease. This is an ailment of the inner ear and it has the same effect as seasickness. Several years ago two doctors from Lymington gave Stugeron to 50 known sufferers and a placebo pill to another 50 victims. The test showed a resounding success for Stugeron. Only then did the makers start putting notices on the box as suitable for seasickness and that it may make you drowsy. In reality, at the recommended doses, it doesn't.Lastly you've gotta BELIEVE in it so I give it a big build up when I suggest others take it.As you may have gathered I speak from a vast experience - having honked my way across the English Channel on many occasions.Since Stugeron, not only have I been completely clear but we have never had a case of seasickness among the various people who have crewed with me. All this for the last 20 years.It works for us so why not for you too. It is a non-prescription drug and I have had two bouts of Menieres - which is far more debilitating than 'ordinary' seasickness.Good luck.
