I'm a new Trailer Sailor & I'm wanting to understand my trailer's tires, mainly so I'll know they are appropriate. Your replies might be helpful to other curious new TS's out there too.My 26' Sailboat sits on a single-axle galvanized trailer with an approx total weight of 2,800#. Both tires carry the following info:SHIELD (Brand)7.00 15LTJL3223 ply ratingLoad Range: D"Single Load: 2,040 lbs at 60 psi""Dual Load: 1,820 lbs at 60 psi"Question: Could someone please give me a brief translation? These are trailer tires, right?Are these OK in your opinion?Should the operating air pressure be 60 psi? I haven't moved the boat yet, but their psi is currently at 45 psi.Thanks for your help,Kevin B.
