Scott Bernhard
1985 Hunter 31. The bilge pump is going off every 5 minutes, worst when heeled to starboard. Can see running water inside hull from very rear of boat, aft of the rudder and just to starboard. Water splits with half running to bilge and some to engine compartment pan (which does not pump). Have checked and adjusted stuffing box, fresh water intake thru hull, exhaust hoses at thru hull, rear lazaratte (dry), emergency tiller, rear cockpit drain thru hull, etc. Can see running water from rear access hatch behind batteries. Help..... this is driving me nuts, where is the water coming from???
