G
George Kornreich
This is in reply to the question posted last month by Albert Shilton. I am in the process of installing the hardware for the spinnaker. The problem of a turning block location was hard to solve, as you have already discovered. The pushpit rail foot was a possibility, but if this has a catastrophic failure under load you could become the "headless horseman". Finally I discovered that the ideal place to mount a snatcd block is at the stern cleat. I removeone of the two large bolts holding the cleat in place by unscrewing it (it is threaded into an aluminum plate which is imbedded in the deck glass), and replaced it with a Wichard eye bolt. Since the screw is english and the bolt metric, I had to drill our the threads in the aluminum plate, and added backing washers. Due to the angle of the bolt as it comes through is not 90 degrees to the inner side of the deck glass, the washers didn't fit flush, at least on the stb side, so I built this up with epoxy mixed with high-density filler (Mixed into a thick putty). The aft bolt of each cleat was left in place. The cleat itself ties the two bolts together, giving it a very strong attachment. Essentially the cleat is now a padeye.Albert, have you already installed yours, and how did you decide to do it?
