Helm/Walk-Through Deck Removal on 320
Steve
Has anyone removed the deck at the helm/walk-through on a 320/326? I can see the two screws from the stern, but I don't know how it is attached to the pedistal. Thanks for the help. Steve
C
Clayton
Simple.
Steve, Remove the screws (my 310 has 4 if I remember correctly), slide the deck aft, and lift it out. Careful not to drop it overboard!
Steve
Doesn't Slide
Clayton, I have had the screws out (the 320 has two, but there is no movement whatsoever. There is some type of attachemt to the pedistal, but I haven't found anything so far. And I'm in Micigan, so the boat is on the hard now. Thanks for the advice. Steve
K
Ken Osborne
Does Slide
Not sure on the 320's, but my 336 does slide aft and up. Hunter did put down some caulk to bed that deck on a lip that helps support it. Yours may just be held in there by that caulk, requiring alittle more effort to get it to break free. Good luck.
Steve
More Screws...
I heard back from Hunter...There are more screws on the side that I have to remove. I'll try it this weekend.
Mike
Michigan help
Steve, What part of michigan??? I work on boats from southhaven on down, Maybe I can help you over the phone.. e-mail me and I'll give you info. Mike mikemm@starband.net
