height measurement from the deck on the mast
May 14, 2022
3
Catalina 30 lake oroville
Anyone have a height measurement from the deck on the mast to mount my spinnaker pole ring. All the other gear is installed but no pole ring. I have the part just don't want to mount the ring too high or too low on the mast.
This is dependent on your sail clew height.
If you are cruising then mount the spinnaker pole ring at approximately the same height as the clew of your spinnaker when flying it with the pole horizontal to the water.
For symmetrical spinnakers, this can be around 4 to 5 feet (1.2–1.5 m) above the deck, but it varies by boat.
When racing, boat owners will use a track so that the pole can be adjusted up or down on the mast as sail trim requires.
