One of the sail trim forum listers, Robert Lang, sent me this info, which I thought mates would find interesting -- especially RichH and Joe from San Diego both of whom might be related to Robert (just kidding!!). What do you two guys think of his explanation??
Good day to you and thanks for all the tips you provide to us, including to me in particular in past e-mails.
Now, I saw your post where you said "I don't know how heeling effects the speed of all boats but I do know the Catalina 30 and the Catalina 25 and those boats sails the fastest (for me) at about 20 to 25 degrees of heel."
I can explain it and do so in a manner that you can see.
I assume that you know that a symetric foil will create lift if the angle of attack is not directly and perfectly on its center line. You can show that by drawing a symetrical foil (plan view, not elevation), place a dot near but not on the centerline, and then measure the distance from the dot to the rearmost portion of the foil. One route will be longer than the other.
Two particle parting at the point of the dot MUST come back together at the same time at the end of their trip. The longer side will have a greater flow and the greater flow will have less pressure, thus causing lift to that side.
Now, ask, what has more force, air at ST&P at 1 MPH or water at 1 MPH? Water being denser has more mass and thus has more force at the same speed. So, given all other things equal, the same foil in water will create MORE lift than the same foil in air. Infact, the difference in lift is INCREDIBLE -- HUGE -- most notable.
Becuae the difference in lift is so huge, where a small change in a foil's shape may create a rather insignificant change in lift, a small shange of the foils shape may create a significant change in the lift in water.
Now, get some three by five cards and a cup of coffee or hot cocoa. Make yourself a nice foil shape out of a card. Keeping the top, create a foil. Keeping it level, dip it in the coffee. It will leave a stain where the level line is. Cut the foil apart from its centerline fron to centerline rear point. Measure the left and right lines. If it is symetric and level, the lines will be equal.
Now, build a similar symetric foil from another card. Dip it into the coffee gain but this time, pretend that you are heeling 15 to 20 degrees. Now, cut apart the foil and measure the left and right lines. The lower line will be, relative to the upper line, shorter. Heeling the boat causes the symetric foil to become an asymtric foil and you need just a bit of change to have a lot of lift.
Now, as you continue to heel, at some point you interrupt the flow over the keel. Intterupted flow provides NO lift. And it is as you start to pass 20 or 25 dgrees that you lose lift, and speed, and control. You actually stall the foil.
That is why some heeling makes you faster while too much (see my avatar) hurts you even as it thrills the crew).
____________________________________________________________
