the dealer we bought ours from told us that when the wind hits 15 knots reef main some and flatten her out. She will take right off. He said too much heel with the big wide stern is like dragging a barn door through the water.These Hunters with the wide sterns and the backless stay riggin will actually sail faster when upright at a shallow heel angle.
This is sometimes a design question. In the olden days, an optimum angle of heel was designed into the bottom shape of around 12 to 15 degrees. Modern designs typically sail better upright than heeling. However, for a sailboat that will plane on her stern quarter, heeling means getting wetted surface out of the water, so the hull actually performs better and it becomes a question of rig efficiency at the heeling angle.I was always taught, anything over 15 is bleeding speed on any boat. Flat is fast.
A very sudden and strong gust with a jibe or a breaking wave can knock you over, but you are unlikely to sail her over. Even then, she will probably pop back up unless something prevents her self-righting, such as the sail becoming submerged. Anchor and chain shift in lockers, engines can fall off mounts, cans, books, heavy stores can fall to one side and make coming back up difficult.Well, I am talking about safety angle on the heeling, before danger of capacities.
I do have heeling meter on the deck.
The 41 DS has a CE certification of A which is an off shore rating. To earn the A rating, her angle of vanishing stability , the angle at which she won’t recover, is a minimum 100 -125 degrees, depending on displacement.Well, I am talking about safety angle on the heeling, before danger of capacities.
Monohull on flat ?? & 00 on the wind, at less on run.I was always taught, anything over 15 is bleeding speed on any boat. Flat is fast.
