Wonder if a fellow owner may have some input ....Kim and I have a Beneteau Oceanis 361 (#329). Kismet has been suffering continuously from heavy steering since she was splashed in April of this year. This week she will be hauled for inspection and installation of fresh rudder bearings."Heavy" means that it requires all fingers from one or two hands to keep the boat on course. When the boat has had a good day only one finger at the end of a spoke would be needed.Steps taken so far: autopilot drive unit disconnected from quadrant to verify that it is not the problem, steering cables disconnected from wheel to verify that wheel and brake are not the problem, all panels and hatches opened to verify that nothing is rubbing on quadrant, cables, pulleys, wheel, shafts, etc., we have nothing jammed between rudder and hull, inspection of rudder on several occasions has shown no indications of damage such as grounding while backing.Further observations: heavy steering has been an on again, off again problem with this boat since purchase in 2004. We are the second owners and purchased the boat in 2005. Boat was originally commisioned in 2004 on San Francisco Bay. From purchase in June 2005 until boat was relocated to Lake Michigan in June 2006 there would occasionally be a day of heavy steering. Steering effort would build during the day's sail. Often, the next day, the steering would be fine. I'd never know how she would steer from one day to the next. After recommisioning in Lake Michigan in 2006 the steering was perfect with never a bad day. Boat was hauled in October 2006 for the winter. Upon splashing this spring the steering was found to be always heavy.Other tidbits: First 40.7's are said to have a similar symptom when they are left in the water and not used. However, the 361 is supposed to use different rudder components. Early 361's (before #250) had similar symptoms due to water swelling rudder components. However, the boat in question is #329 and was built with rudder components from a different source.I know where the problem is, but not what the problem is. I'll know more this Thursday when she's hauled.
