I was close-hauled when I tried,
but after reading the comments I'd say I probably didn't ease the main much or at all and I likely didn't move the tiller full to leeward and keep it there.I was moving forward at 3.9 knots in short order, and the wind wasn't that strong. It was like I had done done a normal tack and ended up close-hauled again.Now that I think about it, I was under the impression that heaving-to would work from any close reach point of sail (from beam reach to close-hauled) just by coming about to the right angle off the wind, and then not adjusting the sails at all. Is it closer to the truth that the window of sail trim for heaving to is much narrower than this? For example, when starting from close-hauled or from a beam reach one would expect to adjust both sails, but if you start at some certain trim configuration (for example, 50 degrees off the wind) then little or no adjustment is required? Is this what I missed?I could simply that question by asking if it matters how the jib is sheeted or does it work across a wide range of jib trim.It may be that when I was successful a few times before I never started from being close-hauled like I was the other day.I'll certainly keep trying and won't give up.On practicing...When I have my sailing buddy with me (we met in sailing class last year and he has a Tanzer 22 on the same lake) we even practice crew overboard procedures, especially if the wind is quite strong to make it realistic.I'll be practicing COB when I'm single-handed too, but I need to find something cheaper than a lifejacket or two fenders tied together to throw overboard! ;-)
