A few days ago I was reading a post about a guy who heave-to on a 1979 hunter 33' Cherubini using just the main only. <Quote>so I headed up, sheeted the mainsail in hard with the traveler down to port, and with the boat effectively stopped, spun the wheel all the way starboard, locked it in place and sat down to see what would happen. With a little fine tuning of the traveler position, the effect was close to magic. As the forward motion stopped, so did the spray. The mainsail stayed filled with wind coming over the starboard bow enough to keep it from seriously luffing at any time and the boat was almost upright, heeling perhaps 5-10 degrees to port. </Quote>I tried this on my boat (Hunter 376 with fractional B&R rig) and couldn't achieve a heave-to last night. although I had some things different. It was only 12 knots true and I was flying my full main only..but it was fully out. I had it sheeted tight and flattened as much as I could. I had the traveler all the way to the port side and then reducing the AWA slowly. When the boat stopped, I turned the wheel all the way to starboard and the boat started to tack so I pulled it back. I played with the wheel position to find the spot where the main would stay filled with only a little fluff at the luff. I finally found a spot where it would stay and locked the wheel. The boat continued on about a 30 degree course (maybe a little less) at about 3 knots. This is a typical feathering, not a heave-to so I didn't achive my objective.Now I don't want to sound questionable about his experience. I'm sure it worked for him and I'm sure that the conditions being different and me having all of my main up was a big factor so I am now writing to ask how a heave-to works with just the main. What counter's the main's drive and the rudder's starboard turn? Is the main supposed to be weaker in force then the force of the wind on the bow? If so, that would mean it's harder to do in meduim winds, right? Has anybody else heave-to with just the main successfully?Just asking because I kind of like the idea of sailing with main only when under one sail now that I tried it. Usually I use the jib only in high winds because the jib helps counter the weather helm created by the heal. So if I can find a way to heave-to with just the main in a blow, then I will definately change my process of depowering to rolling the jib first after a reef because I have a feeling a heave-to will never work just just a jib out (then again...never tried it)
