diesel water heating
my diesel furnace heats water, which circulates through the boat. It is linked to the engine cooling system via a heat exchanger, and then connects to the water heater in the potable water system. For cabin heat, it links to a radiator-type heater which has an independent thermostat hooked up to a 12 volt blower. I have the option of heating the cabin via either the engine or the furnace, and have three means of heating hot water: engine heat, furnace heat, or shore power AC. During the summer months, I can shut down the valves leading to the radiator, and can then have a hot shower while at anchor without having to run the engine. The water lines run under the cabin sole, which means that during the winter I can walk through the boat with bare feet and the boards feel warm. The furnace can also be used to pre-heat the engine, which becomes something of a giant heat sink in the middle of the boat.........Since we anchor out most weekends, the diesel water heater has turned out to be an ideal solution for us. The furnace itself, a webasto, is smaller than a toaster and uses very little fuel. While it is not quiet, it seems less noisy than the forced-air systems. The DC power draw is negligable. It required about 40 hours of labor to install, and cost somewhere in the neighborhood of $5,000, labor included. The only drawback is that when we're sharing a winter anchorage with friends, the party always seems to end up in our cabin. Always.
