A
andy
Has anyone successfully removed the heat exchanger on the Four-91/W30?I can loosen 3of the f nuts, but the forward most nut seems unreachable even with a flex-head socket.How have you cleaned "in-place"?I plan to circulate some sort of cleaning agent (CLR perhaps?) using an old bilge pump.Have you "reamed" the tubes? If so what tool did you use? (I am afraid to force anything through these tubes, which appear to be just less that 3/16")I have NOT tried to remove the exhaust manifoldEngins is in boat and on the hard.Thankspainman
