Tony Wilcox
Hi Gordon,I have a Yanmar 3JH2E on my boat. I want to replace the antifreeze in the heat exchanger. As I have antifreeze in the engine raw water chanels (winterised) there are many drain taps on the engine block, some with a tap and others with a knurled nut with plastic drain tube attatched. which ones will drain the heat exchanger? As I do not want to empty the antifreeze from the raw water engine jacket.Many thanksTony Wilcox
