On the other forums I constantly run into the misconception that the headstay sag should be adjusted at the turnbuckle at the bottom of the headstay. This may seem to be the intuitive answer but it is by no means correct.That turnbuckle at the bottom of the headstay is for adjusting mast rake and absolutely nothing else. The tension in the headstay is accomplished by shroud tension in swept spreaders and/or backstay tension. For those boats like the newer Hunters with no backstay, the headstay tension is directly controlled by the cap shrouds. For this reason cap shroud tension needs to be a higher percent of breaking strength than for those that have a backstay.Headstay sag is a major factor in upwind performance as well as weather helm and degree of heel. Depowering the headsail and moving the CE forward as the wind builds helps to control both of these. A tight headstay that minimizes sag in these conditions produces the best performance and control.
