Weather helm
Harvey,Sailing with the jib only should not dammage your rig. The rig is designed to support the full force of the wind with both sails up. Using only one of them should not be too problematic. Going downwind with head sail only is not a problem either as it is often recommended in sailing litterature only to fly a jib while going downwind to prevent accidental jibe. Some offshore sailors will even fly two head sails, with poles, no main, instead of using a Spinnaker. In this situation the boat is pulled as the front wheel drive will pull a front wheel drive car. A sailboat will have a tendency to turn into or away from the wind depending up on the sail configuration and balance of the boat. The force of the wind produces a "center of effort" and the resistance to this force by the sailboat and keel produces a "center of lateral resistance". If the "center of effort" is aft (behind) the "center of lateral resistance" the boat will have the tendency to turn into the wind. Most boats are designed this way. This is what happen when you keep your mainsail up and the wind is increasing. It is one indication that it is time to spill air from the main or take a reef. Reefing in the main more than the jib will reduce weather helm and make the boat easier to sail. However, some weather helm is desirable. If the "center of effort" is forward to the "center of lateral resistance" like when using a jib only configuration, this will cause the boat to turn away from the wind. This is why you had an easier time maintaining you course with the jib only.Hope this will be helpfull
