I have a 1996 Beneteau OC281 with a z-spar (now US Spar I think) furler. I want to remove the head swivel and furling drum to send in for servicing. The kicker is that I want to do this with the mast up. My plan is to loosen the shrouds and back stays and use both the spinnaker and jib halyards to hold the mast while I disconnect the head stay and remove the furler parts.I'm not sure but it looks like there is not a turnbuckle inside the furling drum and once I remove the drum, there will not be a way to reconnect the stay so the halyards will have to suffice, maybe all winter, or at least until a warm enough day ( I'm a fair weather deckhand) to replace everything.Does this sound reasonable?Anyone familiar with z-spar furlers?Without a turnbuckle, how would I get enough slack in the stay to get it unhooked/rehooked?How would I keep the foils on the stay until I can put things back together?Any thoughts are appreciated.Bill
