thanks for the input
Thanks for the replies guys ... it helped me make a decision. I'm going to go with the Airhead for the following reasons; I don't have to hassle with installing a new tank, hoses etc. and all the headaches that beckons; sanitation (I rather carry a gallon of compost than 20 gallons of raw sewage); simpler system - nothing to break or leak (head, pumps, thru hulls, valves, hoses, connections); simpler maintenance (add peat-stir-empty, add peat-stir-empty); greater holding capacity (holds solid waste for two adults for a month); the (fan) power usage is negligible (.08mA) and can be completely circumvented with a inexpensive solar cell; convenience - if I don't dump urine every couple of days, I can carry a five gallon jug for extended storage, (after all the 50 gallons of diesel I carry is far more toxic than any urine) - I also think dumping a five gallon jug is a lot easier than pulling up to the pump-out and, through the course of pumping out, spraying myself with raw sewage (which I've done). I was intrigued by the Lectra San, but was more concerned by the reliability and less concerned by the power usage (50 amps). Guys who repair MSD’s have told me, the maintenance on Lectra Sans is frequent if they are not used routinely as the plate’s cake up and fail to perform their bactericidal function. I’ve also heard that there was an effort by the USCG to eliminate them because of the maintenance issue and the systems ability to bypass and pump overboard. Peggy thanks for your input. I had thought about damage that could be done but the tank I removed was made of fiberglass and there have been numerous comments in the archives about fabricating custom FG tanks. The very forward locker on the Hunter 37c is not a chain locker, some have converted it to that, but it is originally just another empty locker in a terribly inconvenient place. Lastly, I figured that some place on the boat must be dedicated to a holding tank. At least by using an arguable useless locker as one, I gained a safety feature in a watertight space and I had created a tank space that is accessible for cleaning and/or repairing. I'm not sure I agree that the space cannot be recaptured; with an impervious coating applied to FG hull the space could be easily sanitized with a bleach solution.Scott I think that’s a great idea on moving the deck plate to the starboard side. It certainly cleans up the port locker (I never liked that vented loop in there with clothing, plus it took up so much room). You won’t risk siphoning on a port tack will you?Richard thanks for you input. It's good to hear from someone who has first hand experience, especially where is hot and humid. How ... where did you place your airhead? Its footprint is somewhat larger than the space allowed by the boat.Thanks again everybody … tj
