Headliner removal
  • Thread starter Future Beach Bum
  • Start date
F
Future Beach Bum
Any suggestions on removing the teak strips holding up my headliner? How do you get the tiny little plugs out without destroying the rest of the piece? Thanks
Matt
You have to drill them out.
Take a drill bit that is a little smaller than the plug and drill them out at a low speed. There will be screws underneath the plugs so be careful not to damage the heads with the drill bit. You can use a small screwdriver to remove the rest of the plugs once there is a hole. You can get new plugs at just about any marine store. I have even seen them at Lowe's. Put some glue on them, tap them into place and cut off the excess. Sand until they are flush. Easy enough?
