I doubt it...Most likely a blocked tank vent
Unless someone has flushed something they shouldn't have, I'd bet your holding tank vent is blocked, causing the tank--the whole system--to become pressurized, which is creating backpressure after a few pumps of the toilet. (Whyizzit that a blocked tank vent is the last thing most people think to check when there's backpressure...when it should be the first thing? 'Cuz if air in the tank displaced by flushing can't get out the vent, it HAS to push back.)The easiest way to find out whether it's blocked is to loosen the deck pumpout cap...have a hose handy, 'cuz if the tank is pressurized, you'll have an eruption (I can't begin to count the number of people who've taken baths in sewage because they disconnected a hose to look for a clog before doing this!)...If not, you won't. The most common places for a vent blockage are the thru-hull and the connection on the tank. Start at the thru-hull and scrape it out with a screwdriver blade. Then remove the vent line from the tank and check both the tank fitting and the end of the hose...clean out if necessary.Far less likely in a new toilet, but still more likely than a clog...if the toilet is a PH II, it has an air valve (it's a little flat square doodad with a hole in it on the front of the pump housing that looks like it's molded into it, but is actually threaded in)...if it's defective or has become clogged, it can produce the backpressure you're describing. My money's on a blocked tank vent...but if that's not it, call Raritan for a replacement air valve. 800-352-5630...if the toilet's less than a year old, it's still under warranty. Do not try to use the toilet again or attempt to pump out or dump the tank till you've found and solved the problem...doing so can have disastrous consequences--anything from an eruption in the toilet to a cracked tank.
