With all due respect, Peggy, it works!
What can I say? The diaphragm discharge pump has been in-line for nineteen years, and I have never had trouble using a pumpout station. The check valves all go in the right direction, and the diaphram and the handle on the overboard pump simply move out as if you are pumping...and, voila, everything just passes through. I had to install it this way in 1982 when I moved into a marina that had every liveaboard slip plumbed into city sewage, but you had to have a pump to pump your sewage out. The hose screwed into the deck discharge, in place of the cap. It worked beautifully, and no one ever dreamed of pumping out into the marina. I suppose the marina had a system of check-valves so that no one (or the city!) pumped back into anyone's head. Anyway, I lived there for six years.Regarding my pump set up, it is NOT a recipe for disaster. Think about it, or diagram the hoses. If you have high loops, and if you pump the head dry and actually pump air, any siphon will be broken. And, if you feel uneasy with that, then after pumping your business into the holding tank, you simply shift the Y-valve into the overboard discharge position, effectively isolating the holding tank. You can have an anti-siphon in the overboard discharge hose,in-line after the pump. However, I prefer installing a T, since the way to REALLY have a disaster (as in sinking the boat) is to have one of those anti-siphon valves (approved by the ABYC though they may be) sealed by salt crystals. They then are useless. IMHO, it is much safer to run a loop way up above the waterline (at any angle of heel) and install a T. Run a hose from the T higher still, to a vent, or maybe the cockpit. Nigel Calder recommends this, and it is done alot among blue-water folk, who really do prefer bullet-proof systems. The fact that the ABYC does not recommend my installation may be because they haven't tried it. They don't overule physics and mechanical principles! And, believe me, I have cleared quite a few clogs with this system. Not to mention that when the head needs servicing (I service mine, rather than simply replace), it is easy to fill the bowl with fresh water and then pump it out with the diaphragm pump. It is then much less messy to open up, as I am sure you will appreciate. I really can't imagine what problems the USCG would have with a system that has a holding tank, a through-hull discharge for offshore work, and a deck discharge for pump-out stations, all of which function.........
