Head system leaks
Jerry Woznicki
Could a "vent loop" leak fumes? I have two clamps on every hose connection and still have ordors inside. Could the Hunter installed head hoses have small leaks? This is driving us off the boat. Please advise.
Pete
posible oder
you did not say how old your boat/hoses are but they have a life,sounds to me that they might need to be replaced.
John K Kudera
Head Odors
If you are flushing with sea (bay) water, your odor is possibly coming from the toilet itself. Out of season, see if it is possible to direct fresh water to the head for flushing, and use the Peal products for the holding tank and to clean the pottie. WE did those two things on our H34, and have no odor on the boat from the head.
Peggie Hall/Head Mistress
Before doing ANYthing, read...
There are several articles in the Head Mistress forum Reference Library that address various sources of odor, how to test for them, and the cures. It may be your hoses--but find out before replacing them. It may have nothing to do with your sanitation system...we get calls all the time from people who've replaced their entire sanitation system without getting rid of odors, when all they really needed to do was clean their bilge and/or sumps. So the first step is: find out what's causing your odor. THEN fix that, instead of blindly trying everything. But answer your question about the vented loop: it's one possible source. There should be a check valve in the nipple at the top of the loop that only lets air IN, not out...but if the check valve is missing or has failed and needs to be replaced, it can allow odor to escape. However, if odor is escaping, so should anything else that goes through it...it would also squirt something when the head is flushed. If it's not doing that, then I doubt that the vented loop is the culprit. You'll find a LOT of good information in the articles...and after you've read 'em all, if you still can't find the source of your problem, I'll be glad to help.
