richard
Peggy:In your book, and elswhere, I believe you suggest to continue pumping a manual toilet for some period of strokes even after the bowl is dry to move the material further down the line. I have a Groco HF in a 1985 O'Day 31. The pump works fine evacuating the bowl, but after the bowl is "dry", if I continue pumping with any verve at all, an ounce or two of liquid has a tendancy to spit back up out of the bowl. This can be very unpleasant, as I'm sure you can imagine. If I pump gently, this doesn't occur but I then get the feeling nothing is happening and I'm wasting my time. I have lubricated w/ superlube and changed out the joker valve but this has been the extent of my maintenance on the head since I bought the boat a year ago. Would a complete rebuild fix the spitback problem? Or, should I just live with it and not pump so hard after the bowl is dry. Other than that, the toilet seems to work fine.Thanks for your comments.
