head sink
15
-Hunter 41 DS -2009 port washington ny
We tried our new (actaully 2006) 31' on our first overnight cruise and found that the fresh water flowed in the galley sink faucets but did not do so from the faucets in sink in the head. The water pump was on. Thoughts?
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Try
Try looking for shut off values under main sink,not sure what you have on your model but my 36 has manifold under main sink for all water connections to shut off in case one leaks. Nick
Salty Dog
Check for Kinks in your hose
Check to make sure that you don't have a kink in your faucet hose. I had the identical problem with mine. Found a kink in the black hose attached to the nozzel. Good Luck Salty Dog s/v Carina II
