Head sail
176
Hunter 25 -
1993 H 23.5...I wanted to find any ideads for a novice sailor looking for single handed sailing w jib. Any ideas on "catching head sail" or outhaul line from cockpit so I dont have to go forward as often.
Question #2 How much trouble is mounting a "tiller tamer" on my metal tiller?
TY in advance
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
Mark,
If you attach a downhaul to the head of the jib, run it down to the tack and then back to the cockpit, that should take care of it. Pull the downhaul and one of the sheets snug to keep the jib on the deck.
A very simple tiller tamer is a long line attached to the tiller in the middle with a clove hitch. Since there are no alterations to the tiller it doesn't matter what its made of. I've often used the bitter ends of either the main or windward jib sheet to tame the tiller on the fly.
