Head replumb: vented loop or straight to tank?
Dave
I am replumbing the head on my 1987 Catalina 27. The holding tank is under the V berth and the connection to the toilet pump is high on the starboard side. The previous owner had a "rube goldberg" set up that failed and the head hadnt been used in years. Should I 1)plumb from the Groco pump to the tank with a direct line for simplicity (but vulnerable to heel and joker valve failure), 2)add a vented loop, or 3) get a new tank with the connection in the center of the tank?
Jun 16, 2004
130
Catalina 30 Mk1 Horseshoe Bay, BC
vented loop
assuming the head is below the waterline you should have a vented loop. But I don't on mine. I make sure the thru-hull is off whenever at sea (except when using the head...and then it shuts right off again). I believe in simplicity, but of course if you are forgetful, then a vented loop is the way to go. Happy New Year! -Rob
