Peggy,
Im shopping a 380 catalina, It has reciently been modified with the instllation of a macerator pump hooked to the outflow of the head, and the intake for flush hooked to the pressure water system.
The head is manual. SOO they have a switch to flush and fill, a switch to full the bowl and a switch to empty the boat. all without the hand pump on the head it self.
the pump pulls the water out prettywell untill... the water drops down to the bottom of the bowl then the pump pulls air. when you fill the bowl again, the pump wont prime again as it its mounted above the bowl, s... dont run up hill, a primary rule..
all sewage is pumped into the holding tank, then another macerator and a deck pump out are hooked to the down side of the tank.
Can this work? does it make any sense?
if the pump were located so it would self prime would it work.
Ed
Ed
