Well I checked out the vent hose. Seems to be just fine. Now I bet I have a blockage to the tank. Here's my first question. Do I just snake it like a hose or is there another way to check for a blockage?Next, when I was getting ready to check for the blockage, the Y-valve was bad and wouldn't shut all the way on sea cock side. So I went and found a Marlon Y-valve from West Marine. It had the same configuration for the hoses. Once I got the old valve off am in the position to check for the blockage. I tried to put the valve on the first hose and there must me a magic way to get that valve on that hose. Should I lubricate it? Should I soak the hose ends in hot water? Both? Neither?Thanks so much for your help. The original post for this topic is at:http://www.sailboatowners.com/forums/pviewall.tpl?&fno=4&uid=73231475899&sku=2005040080542.3Photos of the project are at the link.Once again, THANK's for all your help.
