Don Hall
Peggy,I've just taken posession of a new (2000) C36 mkII. Great boat, but already I have two head related problems.1) As you may know, the C36's holding tank is only 15 gal. That fills up pretty fast, even with only two people on board. The existing holding tank does'nt fill the available space under the stbd setee. Do you know if there are larger holding tanks available that will fit in the existing space?2) The boat came with a Jabsco model 29120-2000. The pump on this head doesn't create enough suction to move a wad of TP or firm stool through the flapper valve. Yesterday I had to dissasemble the pump and clear a blockage twice! An unplesant job, and especially anoying on a brand new boat Is there a way to improve the suction of the pump, or is this a characteristic of this model head? 3) I saw in an earlier posting in this forum that you recommend the Raritan PHII head. Would it be worth my time to replace the existing head with a new Raritan PHII? Do you know if the the mounting holes in the base are compatable with the Jabsco?
