Del Wiese
I am the new owner of Grace, 1989 Hunter 37 (yea!). I am trying to figure out the head/holding tank connections and process for pumping out. The plumbing appears to be:1. the hose from the head output goes up to the deck pump out fitting2. a hose from the deck pump out fitting goes to the "input" side of the Y valve3. one output of the Y valve goes to the holding tank input4. the other output of the Y valve goes to the thru hull5. another hose from the deck pump out fitting goes to the hand pump6. the other side of the hand pump goes to the holding tank output7. there is a holding tank vent, from the tank to a fitting on the side of the hullI assume the three hoses going to the deck pump out fitting are connected together by some sort of "manifold"I think the way the system is intended to work is that with the Y valve in one position, the head output is pumped into the holding tank, this would be the normal operating mode.With the Y valve in the other position, you can pump the holding tank through the thru hull fitting, or you can also pump out through the deck fitting.Questions:1. Does this make sense to anyone, am I understanding correctly how the system is connected/operated?2. I am thinking of modifying the connections, if I remove the circuit breaker panel, can I get access to the deck pump out fitting?
