I have owned a 1993 Beneteau 400 for two years and have had constant head odors from the front head. No matter what cleaner I use it seems to smell up the boat when the baot is closed up. On cruise with the windowns open it is fine. I have cleaned out the vent line which when clogged made matters worse. But that did not cure everything. I have considered putting ventilation holes from the holding tank chamber to the anchor locker as well as a solar ventilation fan. Has anyone gone to the trouble of replacing the holding tank and hoses?
