Phil
Like most other Hunter owners, the aluminium holding tank in my 94 Passage was more of a sieve than a tank and required replacement. I had a stainless tank fabricated in Ensenada ($450 US) and did the installation myself. However, even with new hoses the odor in the boat after a few uses was very bad. Thanks to some useful tips from the "headmistress", I determined that the problem was a lack of ventilation to the tank. It would have been a major job to re-work the tank so I came up with another way to get air into the tank.I purchased an aquarium air pump and by making a small slit in the tank vent hose (near the exterior vent), I then fed the small plastic hose down the vent hose and into the tank. With the little air pump running continuously, there has been no further problems with bad odors.A cheap fix.
