Head installation
Tom 410
I'd like to put a manual head and holding tank in my '85 C22 - does anyone have any experience / advice on any facet of this? That is, best location, what size and type of holding tank and where to best put it, any advice or knowledge for the through hulls, etc. She is presently on the hard while I'm working the swing keel, so this is an opportune time to do this project. Thanks for your input Tom
W
WalterK
Catalina has drawing
Tom, Catalina has a drawing that shows a marine head and holding tank installation, and lists the necessary parts. I wouldn't follow it to the letter, it has stuff like glassing in a pipe nipple and threading on a gate valve. It is informative, however. Give David Grass a call, he's always been helpful at faxing out engineering drawings. 818-884-7700. Walt.
john renfro
potty
hi tom . west marine catalog has a section on heads parts laws ect. www.westmarine.com john
Jon Freeman
Head?
I just bought a 1988 C-22, and it is equipped with a factory installed, I think) head in the same place as the porta potty. The tank is under the forward dinette seat. The through hull (there is a Y valve) is pretty close to the head unit and not quite on the centerline. I haven't used it yet. The pump out is in the bottom of the anchor locker, so will be somewhat inconvenient to empty the tank, as will have to remove the anchor and rode. I would consider putting it on the gunwale if I was going from scratch. I am also getting interested in installing a mascerator pump, but need to do a little more research. Anyone have input here? Of course all the same cautions apply to thru-hulls (double clamps, careful installation with appropriate sealants and consider buying the best quality. New plastics with valves seem to be the preferable material and configuration, bronze having apparently lost its pre-eminence). Shut-off valves on thru-hulls are important if you're mooring, according to all the articles.
